okmurdog
Will Ride for Pie
I just completed the 32,000 mile valve check. Almost half of the valves didn't move a lick since the 16k check. All valves are still in tolerance, although some are on the edge of tolerance. All measurements were performed using a go/no-go measurement methodology.
Here's the summary (see attached file for details):
7 valves did not change
5 valves got looser by 0.01 mm
2 valves got tighter by 0.01 mm
1 valve got tighter by 0.02 mm
1 valve got tighter by 0.03 mm
Since #3 front exhaust moved by 0.03 mm in 16k miles and is currently on the lower end of the tolerance, I'll probably perform the next valve check early (40k) to see if it is continuing to move.
