I was wondering if someone could post a clear pic of where to locate the drain screws. I must be staring right at the right place or I just can't see them. Maybe with a circle around the spot. I just got this bike in May and it stumbles up around the 80 mph mark. Till then it runs super.
I have changed the plugs, resealed the gas tank, after a thorough cleaning, replaced the fuel pump with the airtex (recommended by you guys) and the fuel filter also adding in theHonda stabilizer.
I also read that the installed K & N air filter may be letting too much air in which may be causing the problem. I was going to go get a Fram filter recommended on this site and see of that helps.
Any other suggestions.
