Has anyone heard of one going bad? my ABS light started flashing when i went on a ride on saturday. i retrieved the codes and there is no code....that is...the light does not flash, just stays on, no matter whether checking front or rear. service manual says to do several long steps <take a lot of plastic off> and check for shorts or open circuits. if there is no such short or open circuit, its the abs module. found used ones online for about 100 bucks gonna see what a new one cost. anyways, just thought i would post this to see if anyone has had the problem and if not, might have one here. will post results when replacement abs module is installed as to whether that was the cure.
part is also known as abs control unit
