Hello all,
I've got Metzlers on now (Marathon 880 on the back and Z6 on the front). I really like the way these HANDLE much more than the oem Bridgestones, but...I was unable to successfully patch a flat on the Marathon rear. I tried both the mushroom (Stop N Go kit) and the gummy worm - and neither held air. With the oem Bridgestones I had successfully plugged a front tire flat and got another 8,000 miles out of it - no problems/leaking at all.
From what I've read, the steel belts in the Metzlers will chew plugs up. Man, I really am dissappointed if this is always true. I really really like the way these Metzlers fall into turns. Much better than the oem Bridgestones.
I don't like the idea of not being sure I can patch a roadside flat. Luckily, both my flats so far have become evident while my bike sat conveniently in my garage . I'm sure that won't always be the case. Has anyone successfully plugged a flat Metzler? If not, and if I can't expect to successfully do this on the road with these tires, what is the next best handling (similar profile?), non steel-belted tire that gives reasonable wear/mileage (maybe 8-10,000 miles)?
Any opinions appreciated, Brian
