IndyRob
Wanted to ask the group's collective wisdom/advice here...
I am getting ready to leave for an 7 day trip down to the Ozarks (about 2,500 miles total) on Tuesday. Last week my usually trusty 93 ST1100 (58K) left me stranded. After the tow home I checked and the charging system was not working. After testing the stator winding resistance values, all checked out within spec according to my Honda shop manual (Y-Y were all 0.8 ohm and W-Bl was 3.0 ohm, and all checks against ground were open). So I replaced the voltage regulator/rectifier to the tune of $280 for an OEM Honda one and all appears good now. Battery is getting 14.5 volts across the posts above idle and the bike appears to be running fine. After this incident I added a digital voltmeter gauge so I can at least monitor the charging voltage.
In the process of working on the VRR I discovered a small oil leak (5-6 drops each night) dripping from the back of the engine, which I think is probably the dreaded alternator seal leak (I still have the stock 28A unit in place).
My question is... is this leak usually a "minor annoyance" that I can live with until I get back and have time to do the 40A upgrade, or in people's experience does it generally mean the alternator is going to fail very soon (like, within the next 2K miles!) :-( If the stator fails, is it best to unplug the headlight and beeline to the nearest safe place to park the bike? I don't have any other accessories installed...
Any thoughts?
In advance, thank you.
Any thoughts?
