Started new thread so I don't hijack an existing one. Just installed a set. The sky was real dark, but thought I could get a test ride in anyway. I understand they are supposed to be good in the rain, but someone else can do the lightning testing thank you.
The only decent S-turn within miles of here is only about two or three miles from my house. Initial impression on the way there was they are OK. Then as I left the neighborhood and began to gain a little speed I thought wow they are smooth and it rode nice. Then I hit a straight road. Did the old hands off test at 40-45ish (still residential area). Still smooth as glass. Couldn't tell about any pull either way as the wind was blowing too hard, storm mentioned above.
Got to the S-turn and as others have stated I went through it as fast or faster than I ever have and it was effortless. It didn't drift to the outside like it usually does. Turned the next corner and the sky was BLACK. Did the ole 180 and tried the turns a little faster on the way back, even better. I didn't really push the issue too much either as the tires only had three or four mile on them at this point, but I had to push them a little. They were very confidence inspiring. Got home just as the lightning got bad and it started sprinkling.
This is the initial impression, if things change I will post it. So far I give them a
