Hi everyone
I've carried out a brake caliper overhaul many times on other machines over the years, so my questions relate solely to to peculiarities of the ST1300.
I've searched the forum but, surprisingly, couldn't find much in the archives/Articles.
My questions are:-
1. Is it essential to separate the 2 halves in order to remove the pistons?
2. If the answer to 1. is "Yes", then presumably the method that needs to be adopted to loosen the 3 bolts holding the 2 halves of each caliper together is:-
a) remove one caliper,
b) loosen the 3 bolts on the caliper still in place
c) remove the caliper in b)
d) reinstall the caliper in a)
e) loosen the 3 bolts for the caliper in d)
f) remove the caliper in e)?
Do you agree?
I suggest this because it is impossible to reach the 3 bolts with an extension bar while both calipers are in place, as they are diametrically opposed.
BYW, I usually fit EBC pads to all my bikes, but this time I have OEM pads ready. Although brand new, I managed to get F & R for 20% discount on Ebay, and parts still in original packaging. The other reason for changing is that I've been reading a number of articles which suggest that pads and discs should always be matched ie OEM/OEM or EBC/EBC. Will be interesting to see the difference in the stopping power. I haven't measured the thickness of the new ones yet, but they don't LOOK any thicker.
Paul
My questions are:-
Do you agree?
Paul
