Tom Mac 04a
Just threw in a full front set of OEM brake pads... easy job, hardest part was fitting my toothbrush in there to clean well.
But , maybe something I never noticed before... each of the pads had 'sort of bars' lines on the pad material about 2mm high and 2mm wide across the pads.
I can only assume its on the newer pad revision as I don't remember seeing them before when replacing... G01 versions
prob just to sort of let the pad clean the rotor up a bit before full contact...comments???
pic of G02 (second revison)
