1999 ABS / TCS
I wonder if anyone has come across this problem before.
The front brakes are sticking after I have replaced the seaks and the master reservoir seals as well. When I operate the brake the pistons freely move out. However, when I try to push one in, the other pops out. If I jam one of them and push on the other with the g-clamp, there is terrific resistance and fluid does not push back into the reservoir. The only way to get them back in is by opening the bleed valve. As far as I can tell the litte return orfice in the reservoir is clear.
The middle piston connected to the rear brake is fine.
I am hoping I don't have to strip everything down again and that it's a simple fix that I am just not seeing.
