Carb piping
Cambridgeshire - UK
hey!
Im trying to piece an st1100 engine together and need some help
there are 2 plastic t-piece's on the carbs, one on each pair in the middle. What are these for??
thanks
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
The tubing going down from that T goes to the air filter (right?); so, I think the T is part of the vapor recovery system.
Rossi
R.I.P. - 2014/08/28
Nova Scotia, Canada
2000 ST1100
7236
The tubing from that T goes to the little filter at the front of the airbox shroud. It leads to the space under the rubber diaphragm in the carb. It is at atmospheric pressure.
Cambridgeshire - UK
thanks for the replies!
at the moment, the engine is on a workbench, the plan is to put it in a dirt buggy!
all i have is an engine, no other parts of the bike!
should those two t-pieces be piped out of the way of the engine and left then?
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
Without the stock air filter the ST1100 engine does *NOT* run well.
Without that little air filter attached it runs *very* poorly as well.
Cambridgeshire - UK
ok, is there any reason the engine doesn't run well with out the stock air filter, what makes it so special?
and il try putting those two pipes to a small air filter
thanks for the help
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
I know that the bike doesn't run well without an air cleaner.
But although I know you have to have one, the 'stock air filter' part might be incorrect.
So... let us know!
The 'air filter' on the 2 lines is a made of foam; so, don't go overboard on that 'air filter'.
Good luck!
Benton, AR
1991 ST1100
7908
thanks for the help
The jetting of the ST1100's carbs are set for the air filter. Without the air filter the fuel mixture is TOO LEAN. My '91 will only rev to 5500rpm with out an air filter in neutral.. I once ran an Amsoil foam filter. With the filter properly oiled (not too much oil) my bike would loose power at full throttle. Ran fine the first 7/8 of throttle, open her up she would stumble. The Amsoil filter flowed too much air and it ran too lean. I installed a Fram and the bike runs perfect.
Benton, AR
1991 ST1100
7908
So... let us know!
Good luck!
Good luck![/QUOTE]
Go down to where lawn mower parts are sold. Usually they have a green foam air filter material. This works great for that little foam filter.
The Dan
The Dude Abides
Vendor
Watertown SD
2009 ST1300 ABS
7982
The tube is so there is filtered air going in and out of the top of the sliders when they slide up and down. If not then they would fill with dust and screw up.
Kingman, Arizona
2000 ST1100 ABS TCS
004
hey!
thanks
All the info ya need is in these notes...
Get ye to a breaker and pick up a stock air filter box. Should be cheap as there's plenty of parted-out STs and little call for the air box.
