Have not run the ST1100 at all this summer and when I started it up for fall riding I had a miss. Pulls fine and runs ok under load but not at steady throttle. I checked the carb sync as per the posts on this forum and carbs are pretty close. Have isolated the problem to the #1 cyl. Pulled the carbs out and the bowls were showing signs of sediment, etc. Not sure how involved I need to get from here on out? I am thinking of pulling the main & Pilot jets out and just blowing everything out with carb cleaner. Will that be enough? Do I need to check the diaphrams?? Runs good under load..
