The Synchrometer is what I use...it's so easy and works.
I had no problem getting the carbs synced using my Carb Stix and making the bike run marvelously (night and day difference), the problem is it not staying that way.The Synchrometer is what I use...it's so easy and works.
This makes sense to me too. ThanksLikely won't stay unless the sync was done with airbox/filter in place, or if cooling fan comes on during process, or if you didn't shut it off and blip throttle several times to seat the screws stable, re-start and check again...........a few time process to get all stabilized.......a ten minute sync ain't gonna cut it......for any length of time anyway. Use an external cooling fan on the floor of the man-cave to stave off that cooling fan coming on......helps speed up the process a bit.
Hmm, I must be pretty lucky then. The 5 or so ST1100s I've synced with the Flowmeter (3 of which are mine), seem to stay synced without all the fuss.Likely won't stay unless the sync was done with airbox/filter in place, or if cooling fan comes on during process, or if you didn't shut it off and blip throttle several times to seat the screws stable, re-start and check again...........a few time process to get all stabilized.......a ten minute sync ain't gonna cut it......for any length of time anyway. Use an external cooling fan on the floor of the man-cave to stave off that cooling fan coming on......helps speed up the process a bit.
+1Hmm, I must be pretty lucky then. The 5 or so ST1100s I've synced with the Flowmeter (3 of which are mine), seem to stay synced without all the fuss.
Agree with Uncle Phil. I've only needed to do mine once since 2007 and I started by first thoroughly cleaning then mechanically synchronizing the 4-pack. Then I used the vaccuum method as specified by Honda. Maybe you should clean things up and check your linkages first, too.Hmm, I must be pretty lucky then. The 5 or so ST1100s I've synced with the Flowmeter (3 of which are mine), seem to stay synced without all the fuss.
Yes, I have. I completely dismantled my carbs back in /07 when I had just bought the bike. Wanted to clean up everything in there before synching them mechanically. Followed that by the standard Honda vaccuum synch as shown in the shop manual.has anyone ever removed those screws 'n springs? I'll be surprised if we get an affirmative answer.
YepPat, simple question here: has anyone ever removed those screws 'n springs? I'll be surprised if we get an affirmative answer.
