RocketMan
so many roads...
Hi,
Today Rubberdarts and I installed my CCS-100 recently acquired from Murphskits.
Rob has done is own as well as Norm's (also bought from Murph's and installed 3 weeks ago).
Both work.
I got the relay because I have the LED Spoiler on my Honda Top Box and also some Hyper-Light flashing LED brake lights.
Pressing the ON button does nothing. The green light does not come on and the unit does not stay on.
From the troubleshooting sheet there is 12 VDC at the red wire.
The brown wire only has 12 VDC when holding the ON button. Releasing the ON button and it goes to 0 VDC>
Oddly, the brown button also goes to 12 VDC when pressing the OFF button.
Purple wire is fine at 12 VDC when front or back brake applied. This is true when connected to ground or when run through the relay.
Green and Yellow wires pass the close Open Circuit Switch tests but the Green wire fails the Closed Circuit Switch test (12 VDC when Set Coast is pressed and 0 VDC when Set/Coast is released)
Yellow passes the the Closed Circuit Switch test.
From the ST site here we found some info on the LED In the Servo. When pressing Set or Resume the LED stays on steady instead of blinking.
Wondering if anyone has any insights?
I've sent all of this to Murphs as well to see what they think might be wrong.
Thanks.
Bruce
Both work.
Thanks.
Bruce
