- Joined
- Feb 5, 2005
- Messages
- 8,537
- Age
- 77
- Location
- Kingman, Arizona
- Bike
- 2000 ST1100 ABS TCS
- STOC #
- 004
Took some pictures yesterday while changing out ReSTored's front tire. A couple comparison shots between a Dunlop D205, 110/80/18 and a Michelin Macadam 50 110/80/18. This illustrates a point I mentioned the other day about the relative width between the beads between nominally the same size tires.
Dunlop 205 - - - - - -- - - - Michelin Macadam 50
side by side inside = = = = =side by side outside
Believe me, there's a _big_ diff when trying to seat the beads. MotoMac gave me a hand mounting the Michelin. We had to pack the crevice between the rim and one side of the tire with mounting lube to build up enuff pressure to get those beads to spread.
Sorry I didn't get pics, but when the beads _did_ spread, the lube flew off the wheel like a custard pie headed for the target. The target? Oh, yeah, Mac had just donned a fresh t-shirt. LOL!!! I was crying! :lol::lol::lol: (Sorry, Mac, it was funny! )
Can you say Karma? I knew you could. After getting the tire mounted, I was closing down the compressor when the regulator fell apart in my hands. Ugh! New one sourced this evening for $26.
So, before applying the new tire, we had to break down the new tire. Wanted to try a technique I saw demonstrated at CampSTOC 2008. Will broke down Landon's tire using only tire irons. I've tried it before without success but thought this was a good opportunity to try again. Mac took some snaps as I struggled with the wheel.
So, basically, we pushed the bead of the old tire all the way round to make a little room
Then, we applied a little soapy water to act as lubricant
Now, put the point of the tar arn _point side down_ and lift _up_ to push the bead down into the well,
and use the second iron as needed to add a little more leverage.
Once the bead is broken down, reverse the wheel and do the other side.
All else is per normal, pry the tar off and replace with the new one.
Why do this when I have a perfectly good HF tar changer stacked in the corner? Cause I'm more likely to change tars in the field as I am at home. Hard to pack an HF compared to a set of tar arns.
First lesson, tho, is the width of the beads. I do believe I can seat the beads of that D-205 using my 12 V compressor. The Michelin required hi-volume air at 120 lbs, with extra "goop" applied to provide a seal. There are big diffs in tires and we're all still learning.
I'll let y'all know about setting beads using a 12 V compressor when I install the Dunlop on STick's front wheel in a couple months. The current Avon still has a ways to go.
