I have a 2002 ST1100 and its leaking. Should I buy the kit to rebuild, buy a used Master Cylinder (forget buying new OEM replacement, too expensive) or buy the Chinese after market on eBay.
+1 Heathy, Where's it leaking from? I presume that it's out of the pushrod end, if so go with a rebuild kit as long as the bore looks OK.I have a 2002 ST1100 and its leaking. Should I buy the kit to rebuild, buy a used Master Cylinder (forget buying new OEM replacement, too expensive) or buy the Chinese after market on eBay.
Yeah, it takes 15 minutes to get to Fillmore. Take 23 right to it. I take the side route off 23 to go to Santa Paula, and through there to get to Ojai. Went riding to see much damage the fires did here. Found that the restaurant I stop at on Kanan was burnt to the ground, not far from the Rock Store.Check the service manual? Download it if necessary, I'm sure it's available. The process to rebuild the MC is pretty simple, but you will need one special tool . . . a pair of circlip pliers to remove the retaining clip. The process is simple and there are only about 5 parts to replace during the rebuild. You might want to consider putting in a new sight glass as well when you do the MC, if it's all clouded up.
Moorpark, huh? I grew up right around the corner from you, in Fillmore. Some awesome rides thereabouts.
I have flushed the clutch master cyclinder through the slave cylinder on the front, as the fluid was pretty dirty when I purchased the bike on 12/31/2015, so I know what you're talking about. I have rebuilt a master cylinder on a car before, but that was some time back. Anyway, I figure to get as much info as possible before I start on it.+1 ABSU. The piston will be retained by a circlip. So remove your lever first, there's a locknut underneath, note where the pushrod nestles in on the lever, this is the bushing you will need to ckeck. They can and do wear out.
The circlip shouldn't be too bad if it's had fluid around it, they can be a bugger to tease out when corroded. Then the piston should pull out. Your mobile will be your best friend, pictures, pictures, pictures. Much easier than wondering where that bit goes later. Also full bleed will be required after but the slave is at the front on 11's.
If you can find the manual to download it would be good.
Hope it helps. P. S. All above is from memory only.
Upt'North.
I have a non-ABS, but there isn't any issues with the brakes, just need to fix the clutch side as the fluid is leaking onto the bike. I have ordered the kit and it is due this Thursday, 12/13/2018.If you have a non-ABS model, consider buying a new Brembo 12mm master cylinder. I installed one on my non-ABS model and the "brake feel" is much improved - a lot less "wooden".
When I purchased my ST, I had a broken left arm from crashing, shattered my wrist. Crashed 11/19/2105, found the ST online in December, picked it up and trailered it on 12/31/2015 along with my brother who test drove it for me. Then since I couldn't ride un February of 2016, I spent my time online, to which I did download the PDF manual, along with the actual manual the seller gave me. What else could I do waiting for my arm to heal so I could finally ride. Best thing that ever happened to me was getting my arm broken in that accident. Person who caused me to crash had a one million dollar umbrella policy to which my settlement check will arrive next month. Now looking for a 2nd bike, V-Twin, as even though the ST is great, it is the same ride every time, and I need a change of pace. You know, ride one, one day, and then the other the next.You'll find a link on the Australian Pan Site to download a free PDF manual. I think it's the bottom post that works.
Upt'North.
http://ozstoc.com/index.php?topic=433.0
that's crashed 11/19/2015.When I purchased my ST, I had a broken left arm from crashing, shattered my wrist. Crashed 11/19/2105, found the ST online in December, picked it up and trailered it on 12/31/2015 along with my brother who test drove it for me. Then since I couldn't ride un February of 2016, I spent my time online, to which I did download the PDF manual, along with the actual manual the seller gave me. What else could I do waiting for my arm to heal so I could finally ride. Best thing that ever happened to me was getting my arm broken in that accident. Person who caused me to crash had a one million dollar umbrella policy to which my settlement check will arrive next month. Now looking for a 2nd bike, V-Twin, as even though the ST is great, it is the same ride every time, and I need a change of pace. You know, ride one, one day, and then the other the next.
