JZH
International Bodger
It's been a while since I've upgraded any of my heated gear, which mainly consists of vintage Gerbings and Warm n Safe controllers sporting the old SAE/trailer connectors. I've decided to tiptoe into the 21st Century and convert to the now-standard "coax" connectors, but I am concerned about the power handling capabilities of this connector. The connector is a DC power connector measuring 2.5mm x 5.5mm. Most such connectors I have found seem to be rated by their manufacturers at no more than 5A, yet the dual wired Heat-Troller I've got came with a 15A fuse. With a dual controller with only one connector plugged in, wouldn't that potentially mean that the fuse would not blow until all 15A had gone through that one connector?
Another way of looking at this, however, is that with thousands of these connectors being used on a daily basis, I would have heard if there had been any problems associated with "overloading" these connectors by now...
I am assuming that the moulded connectors being used by manufacturers of heated clothing are not "special" high current versions not available anywhere else--the days of proprietary electrical manufacture are mostly long gone--virtually everything is available on Alibaba! In my current installation I would like to use a waterproof (IPX7) coax power socket (made by GTC), but it, too, is only rated for 5A. Perhaps I am worrying too much...
Cheers,
Cheers,
