Checked the wires and knock sensors to ecu they were both fine , put a new ecu in and still get code 25 , what to do next ?
In 30+ bike repairs, it has NEVER been one of those three.If you are lucky;
- a faulty knock sensor.
- a defect in the wiring.
- a defective connector.
That well may be but, there have been at least two or three on this forum who have claimed success with one of those three. That makes it a long-shot for sure, which is why I prefaced this statement by writing that luck would need to be on his side.In 30+ bike repairs, it has NEVER been one of those three.
Good observation ...I found on a 2003 st1300 has stored code 26 The bike has a melted connector and right knock sensor.later yr bike has improved heat shield in this area.So everyone saying they need new ecu Needs to look for this before condemning ecu!!!!
Of course it's a good idea to check thoroughly before spending $800+ (unless you can find one used) for a new ECU. However, many who have had this code have swapped sensors side to side, replaced one sensor with a new one, and still experienced the fault code. Note that there are at least two different ECU's based on the age of the bike.I found on a 2003 st1300 has stored code 26 The bike has a melted connector and right knock sensor.later yr bike has improved heat shield in this area.So everyone saying they need new ecu Needs to look for this before condemning ecu!!!!
