some members have stated they can't see that the outer pad is fully seated on the caliper correctly when installing new pads without removing the wheel ect.,the inside pad is easy to see,but I found if you look through the one half inch gap between the top of the exhaust pipe and subframe using a flashlight the most foward part of the outer shoe location is plainly visible.
