I'm just trying to confirm the SMC is causing my rear brake drag on my 2004 ST1300A.
If I push on the SMC it will stop the rear wheel from spinning but when I release the SMC the rear wheel drags. Likewise, when I press on the rear brake pedal the rear wheel drags. From the research I have done on this site it appears I have a faulty SMC. Does this sound right?
Can the SMC bracket assy be removed from the bike and the piston set be removed & cleaned without going through the brake bleed process? Approximately 10,000 miles ago I followed the instructions in the service manual & documentation on this site to replace my brake pads & brake fluid. But, I was hoping for a short cut to try cleaning the SMC piston.
I have found the following information on this site:
45620-MCS-G03 piston set
06454-MCS-G02 bracket sub-assy
Are these the parts that most folks have used to repair their SMC?
I still have extended warranty coverage on my 04 so I'm hoping Honda will take care of this for me. But if not I wanted to make sure I was on the right track.
Thanks,
tman
Thanks,
tman
