I am getting ready to change the coolant and thermostat on my 03 1300. While I have the plastic off is there anything else I should change out or check at 50K miles?
You will see it once you remove the radiator...I have all the plastic off and I have a factory service manual, but I cannot locate the thermostat housing. Anybody got a pic on where to find it?
Remove the radiator and the cross member that connects the left and right frame down members. The T stat is behind that cross member in the Vee of the cylinders. You can follow the large radiator hose from the left side of the radiator to the T-stat housing as well. If you send me an email I'll send you a tutorial that is easy to use for this job. PM me.I have all the plastic off and I have a factory service manual, but I cannot locate the thermostat housing. Anybody got a pic on where to find it?
What is the check valve you're referring to?And agree on bleeding the check valve, as well as all the calipers since the plastic is off. Otherwise, all I did was clean out all the dead butterflies and bees.
Tom on the N. Side of SA
