SS, thanks for your e-mail and camera looks great. I could of used it when tracing the leak. Now, I know I should of remove the radiator to toghten clamps for t-stat housing but I didn't. Like I said,, t-stat was replaced at around 26k miles, radiator removed and flushed etc. Funny thing is, I don't think I even checked those clamps and now I know I should of. I have to say, I hated the mess of coolant while removing radiator. Yes, I had the pan under, rags and still mess was there. So this time I went from the top, lift gas tank (not remove it), removed air cleaner housing and snorkles all the way to throttle bodies. I checked for signs of dry/wet greenish traces of coolant and found one of the hoses to be the culprit, the lower hose on t-stat housing. Clamps were facing forward and was able to tighten them. Lower one kind of hard to get to, but whole t-stat assembly you can move up and down, side to side. I pried it upwards and retighten the clamps. I must say, the bottom clamp was pretty loose. I ran for a while till fans kicked in and seen no coolant or smell coming out, hope it stays that way. Washed the front of engine (waterpump cover) to remove all stains from the leak. It took couple of hours plus tupperware another hour, but now I know it's done. On top of that I replaced a front tire. I'm good to go. Tx for all your comments and replies.
