Ok guys..I am in need so some good help here...I think I have a forest in front of me but I just can't seem to see the tree..I have just installed a Rostra electronic servo cruise control on my ST1300 and it doesn't work!!!
Completed installation..set dip switches...did complete diagnostic test and all passed..All PASSED!..Instead of buying a divide by two converter I made my own (am an electrical engineer so I would rather spend $300 to build my own than $30 for a store bought one!)
I hooked it up to a dual trace Oscope and input from bike's hall effect sensor is a pretty 5v peak to peak square wave..the output of my converter is a pretty 5v peak to peak square wave at exactly 1/2 the frequency. IT even "sees" the speed signal (flashing led) when I do the speed sensor diagnostic. I checked my ground to the low side of the brake light (violet wire I think) and it is less than one ohm to battery negative. Every thing seems to be in order but when I put it up on the center stand and run the bike up to 60 mph in gear the system will not engage. I am NOT using the "set" control at all..I am using only two buttons..the "resume" (am using this as a set since that is what the crappy manual says) and I am using a latched 12 vdc source to the red wire with brown tracer so that when that button is pressed it latches in and holds 12 volts on the red wire with brown tracer. The damned thing should work..why not? Is the fact that I am not using the "set" button at all (green wire) causing the unit to not set? Does the Rostra unit need a higher voltage peak to peak square wave speed signal? Throw me a bone here!
kingrj
kingrj
