After ~16 months and 'tens' of tire changes with my Cycle Hill changer, I thought I'd follow up with some comments & observations:
1) It
hurts a lot when I bang my knee on one of the arms or into the rim clamp adjutment knob!! Doh, it seems that I've done that every time I've used it. :nuts1:
2) The bead breaker
alone is worth the price of admission!
I'm glad I opted for the delrin version of the bead breaker paddle.
3) The rim clamps by design are NOT positively retained on the arms--that continues to be an annoyance and design flaw IMO (see post #22 above). Strapping down the rim to the arms has proven to be necessary to avoid the rim and rim clamps suddenly popping upwards and off of the arms, which usually happens just as I'm starting to put force on things while trying to remove a tire. I now take the time to strap down the rim with 3 separate straps, one to each of the three arms--2 straps has proven insufficient. Without 3 straps, it is too common that as I lift/pry off the old tire one of the rim clamps will pop out. :banghead: A significant design improvement can be made on this 'issue' IMO.
4) The only dowell provided with the changer which fits through the bearing inner races on ST rims is too sloppy (the dowell is inserted through the axle hole in the rim to 'center' the rim while it is clamped down, and it is also what you pull the nomar tire iron against as you pull off or put on a bead). I hope to get a larger diameter dowell (one which is slightly smaller than the ST's axle bolts) and I would like to add a shoulder onto that dowell. The shoulder will be used to rest the tire iron against as I lever it around the circle. I've had several instances when I'm levering the tire iron around the circle (pulling off a bead) and I realized that the tire iron has slid down on the dowell and the
disc brake rotor is holding up the tire iron.
: So a shoulder needs added to the dowell so that the tire iron can't drop onto the disc rotor. (Make sense? If not, I'll add a sketch later)
5) The sloppy bead breaker joint (see post #8 above) turns out not to be an issue. The bead breaker is used for only a short time and its slopiness is inconsequential.
6) The original delrin tip on the tire iron remains in service, but is weakening & stretched where it mounts into the metal. The package came with a spare, but I haven't had to use it yet.
7) A safety observation: The dowell should NOT be in the center of the rim as a new tire is being pushed onto the rim (that first bead usually can be pressed down over the rim with hand force). If the dowell is installed, while pushing that tire down it is easy to push your torso, head, or neck onto the dowell! So, keep the dowell out of the way while pushing the tire's first bead down onto the rim.
Would I buy another one? Yes. It remains a good purchase and I'm happy to have it, but could use some fixes to the design.
