mlheck
I am in the process of replacing the springs on my ST1300. I replaced the front springs with 1.2kg/67lb. sonic springs and have set sag at 30.2mm. This number stays the same with, are without my weight on the bike. I weight 175 lbs. with no gear on.
On the rear I installed a Racetech 21.4kg/1200lb. spring and set rider sag at 31.75 with 13 complete revolutions of the preload knob, and I have refilled the oil in the preload. My free sag on the rear is 15.9mm after setting the rider sag. According to Racetech's information included with the spring, and which is the same information found in Lee Parks book, this spring is too soft.
I am concerned about the front not really changing with my weight, and the rear seems to change to much. I went with the 1200lb. rear spring based on Racetechs chart and information posted by some of you that have already made this change.
I know the the setup is more based on want I find comfortable, but I need to start out close as I am NO suspension expert.
