So I'm thinking of getting the Sonic springs and changing the fork oil...can I suck it out of the fork tubes or do I Have to pull the forks.....looking for the easy way out.....thanks guys.......flyfisher
These are cartridge forks so sucking what fluid you can out of the top leaves a large amount still in the fork. It is not even easy to change the springs out the top ....... the handlebars overhang the fork caps.
It really isn't that hard to drop the forks out once you get started.
The forks have compartments inside them that trap fluid.
If you don't pump all the fluid out and then add the *right* amount of fluid you will have more fluid in the forks than you should/need.
It isn't easy to pump all those compartments empty either.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
