Which parts do I need to order from Electrical Connections to wire my
05/st1300 ? My trailer has a standard 4 wire plug. thanks for your help
Okay, my curiosity has been piqued. What is it about the ABS brakes that a isolator is recommended, but not necessary for the non-ABS brake bikes?With ABS brakes I was advised to use a isolater connection for trailer
Actually, it's recommended for both. You don't want the additional trailer load of lights inline with your bikes lights, you could blow a fuse and have no lights at all. So, an isolation relay will power those lights from the battery and trigger them via the relay from the bikes' wires so there's much less of an impact on that system.Okay, my curiosity has been piqued. What is it about the ABS brakes that a isolator is recommended, but not necessary for the non-ABS brake bikes?
