I've just spent the last 5 hours trying to bleed my brakes. I didn't have any problem removing the old brake fluid. I measured about 6 oz. of brake fluid removed from the entire system. Does that sound like an appropriate amount? I am using a Vacuum Bleeder (not a cheap one). I followed the Service Manual. But, still following the SM, and after reading everything I could find on the forum, I have only been able to successfully bleed the PVC and the Rear Center brake.
FRONT: Fill reservoir and pump brake handle; no air comes out of Master Cylinder and no resistance in handle. Bleed Left Front Outer caliper. Lots of air, some fluid, fill the reservoir 3, 4 or 5 times; I really didn't count how many times I filled the reservoir, but it was a lot (just for the LF outer). Still getting air, and some fluid. Keep filling reservoir. Still get lots of air, some brake fluid. So, am I doing something wrong, here? I figure that maybe the air I'm seeing is from around the bleed screw, so I move onto the Right Front Outer. Same story here. No resistance in the brake handle, so there has to be more air in the system. I just can't figure out how to get it out and why it's taking so much bloody brake fluid with no results!
The trouble is I am not getting the solid stream of fluid I expect to see. I see much more air. BUT, I've gone through three bottles of Honda DOT 4. Is this typical, or am I really a dufus, here? I've bled brakes before, but never on a motorcycle. I've never had this much trouble bleeding brakes when I've used a vacuum brake bleeder.
I have no clue what I'm doing wrong.
Your sage advice is sorely needed. Thanks in advance.
