Hi Dave. The clip is the tipoff - means that the upper section of the fuel filler cap's vent hose has detached from the inline T connector near the bottom of the ST1100. The T is a secondary/backup vent to atmospheric for the fuel cap. There should be a short length of hose on the other side of the T that extends the line to just below the engine. It's one of three hoses that all end in the wire bail above the rear extension of the lower fairing, left side. Have a look at the Fuel Tank online fiche. HTHThank you Ray just the end of the pipe as got a ring clip on it ???
Good to know, mine may be blocked, too ( 1998 ). I'll be checking that in the spring, before I'm back on the road. The list is getting longer - check valve clearances, install Rostra Electronic speed control, install highway pegs, install MP3 player & SiriusXM radio.Hi Dave. The clip is the tipoff - means that the upper section of the fuel filler cap's vent hose has detached from the inline T connector near the bottom of the ST1100. The T is a secondary/backup vent to atmospheric for the fuel cap. There should be a short length of hose on the other side of the T that extends the line to just below the engine. It's one of three hoses that all end in the wire bail above the rear extension of the lower fairing, left side. Have a look at the Fuel Tank online fiche. HTH
