Yes I checked both fuses, thank you.Did you check the headlight fuses?
The passing light and headlight are separately fused.
That is very helpful info, thank you Roger.Hi beam relay is OK. So, corrosion in the - headlight supply fuse, headlight switch (if you have one), Hi/Lo switch........?
I did think it was unlikely that both fuses would have gone - but if they had, you'd have a separate underlying issue.Yes I checked both fuses, thank you.
Thanks I will look into thatThis happened to my son once. It turned out that the right hand switch has a little piece of plastic in it that broke and that kept the headlights from coming on.
From our trip report (2014):
"...the starter switch is held together with a small nylon holder. The one side had cracked and wasn’t holding the switch together, allowing the contacts to lose connection..."
I just did that, everything is back to normal, thank youClean your starter switch housing with plastic safe contact cleaner.
It was a sticky start button, thank you for helping.Hi beam relay is OK. So, corrosion in the - headlight supply fuse, headlight switch (if you have one), Hi/Lo switch........?
It was a sticky start button, thank you for helping.I did think it was unlikely that both fuses would have gone - but if they had, you'd have a separate underlying issue.
Sounds like it's time to get out the DeoxIT!
Thank you, after reading your feedback, I had a sticking switch in the starter circuit. A bit of plastic safe contact cleaner and working great, thank you for your help.This happened to my son once. It turned out that the right hand switch has a little piece of plastic in it that broke and that kept the headlights from coming on.
