- Joined
- Mar 18, 2006
- Messages
- 2,855
- Age
- 70
- Location
- Ilkley, W Yorkshire, UK
- Bike
- 2013 ST1300 A9
- 2024 Miles
- 000679
- STOC #
- 2570
I would go along with that. After moving from the 1100, we took the 1300 camping and I wound up the rear suspension to compensate for the extra load. When we got home, I forgot to take off the extra pre-load and the bike felt skittish. It was frightening and felt as though the front wheel would tuck underneath the bike if I turned left or right.I suggest as an experiment to lower the rear suspension an appreciable amount, and keep track of how much to return it, without making any other changes, and see whether it makes any difference in stability. I'm betting it will.
These days, it doesn't bother me a jot if I leave the suspension up high. Which is a good indication of how my expectations of how the bike should behave actually affects how it does behave. Anyone tends to react to what they think is happening - but we are not computers, and we react late, which tends to make the problem worse.
You can demonstrate this effect on a push bike. If you have a bike with the older style of adjustable ball races in the headstock (ie an adjustable cup and a large locknut, tweak them a tad too tight so that the steering feels a bit stiff. Then get on and try to balance the thing. It slows down the speed of your reactions and the bike wanders all over the place as a result.
I'm not saying that a wobble exists for some riders and not for others. I'm saying that the bike AND the rider can be very sensitive to changes in the settings. Sometimes for the best, sometimes not. One thing at a time to get used to the new settings for a while. Then do the comparison test - back as it was, and then the new settings to make a comparison. Then something else.
