Tonight I performed surgery on the GS850.
The heli-coil that was put into cylinder 3 before I bought the bike came out the other weekend, so I bought one of these and installed it tonight
http://www.amazon.com/Perma-Plug-1-25-Spark-Plug-Repair/dp/B0025PMJHA/ref=sr_1_1?ie=UTF8&s=automotive&qid=1282277418&sr=8-1 <<-- Perma-Plug M14 X 1.25 Spark Plug Hole Repair Kit
Pretty painless... and yes, I am lazy, and yes, I did leave the head on the bike. I put #3 at bdc and then coated the tap with axle grease and went after it, backing it out to clean and reapply fresh grease after every few turns. It worked beautifully, and I was done in about 30 minutes. There was one small piece of aluminum lying on top of the piston when I got finished, which was easily picked up by touching it with a screwdriver. I had the shopvac and a length of tubing on standby to chase wayward chips out of the cylinder, but turns out I didn't even need it.
I then put some Loctite red on the outside of the sleeve, some anti-seize on the spark plug threads, and installed the sleve. After hitting the expander a few times with a hammer, I threaded in the spark plug. It's all back together and torqued down now, and the bike fires up just like it did before.
