Kaoko Question
NSB Florida
2018 GL1800 DCT Tour
It looks as if Kaoko is the only one making a throttle lock for my new bike. I have read what I can. I see that if you roll the throttle off it unlocks. My problem with that is that I set the lock and then adjust my throttle slightly up and down as needed. Is it going to cancel when I try to adjust the speed down a little?
Thanks
Skunkape
NSB Florida
Throttlemeister doesn't list one for the Triumph 800XC. I would still want to know the answer to the same question if they did.
Parma Ohio
2007 ST1300
The Kaoko doesn't lock per say. It is a variable friction that you can leave at whatever tension you desire.
It works by pushing against the throttle and the more you adjust it, the more tension it takes to move it.
Dennis
