Length of Oxford Heated Grips
I remember reading here the various lengths of different models of Oxford Heated Grips. Does anyone know where this was posted or better yet, the lengths of these grips? I did a search for 'Oxford' and 'Heated Grips' and came up dry.
Thanks.
Schroon Lake, NY
2010 ST-1300
I measured my stock grips and they are 5". Was wondering if it was better to get them slightly shorter or longer?
LSAC, AB & Indio, CA
2005/06/07 ST1300
Like I said I like the grip on mine and size. They fit very snug, especially the throttle side so dry fit them first and note that the glue sets fast. Really read the instructions first and follow them.
Rochester, NY
2008 ST1300
8441
I got the Adventure grips, using with the OEM honda controller. They fit perfect, though you can trim the ends a bit if too long in your app.
Schroon Lake, NY
2010 ST-1300
Did you have to trim the grips or shim the ends to keep the throttle from binding with the end weights installed?
Rochester, NY
2008 ST1300
8441
I have a throttlemeister lock and had to trim the throttle side a few mm.
A cramp buster thingy covers my shoddy cut job lol
The left side I left full length and it fit nice to the weight.
Frisco, Texas
2015 BMW K1600GT
Also note the diameter of the grips. The smaller of the two is the one you want (can't remember the exact diameter) but Honda's are smaller than the cruiser grips.
rogo
Duluth GA
'05 ST1300
000406
The adventure grips are about 1/8” longer than my stock non-heated grips. They fit nicely after I shimmed out the end weights with a couple washers I cut in half.
I didn’t want to trim the grip down because the end weights diameter would be longer leaving a slight step.
