Hi,
I changed my brake pads with new recommended OEM. I have a hard time trying to push in the 3 pistons with the old pads, only the center piston retracted,finally i give up and let some hydroulic out of the caliper thereby retracting 3 pistons and installing new pads. I also changed the front left pair of pads as they wear more than the right, and i have no spare to change the front right.The front pads seat without a problem, as for the rear i have to let air out by manual bleeding as i have no bleeding tools. The brakes were firm and seems to work fine, it just occured to me to check the function of the linked brake. I sat the bike on center stand, press back seat down and rolled the front wheel,immedeatly engaged the rear brake pedal, the front wheel stoped, i grinned to myself and repeat the process with the rear tire and engaged the front brake handle. The rear tire just kept on rolling. Is something amiss.(see pics)
