Hello all,
I have (or better say had) a very strange cause of my rear break drag (see "Irresolvable rear brake drag" thread I have posted previously). After reading everything regarding the rear break drag on this great forum, and after trying to fix the problem myself for a year, and after having the bike at a HONDA dealer for one month and replacing the Secondary Master Cylinder, delay valve, proportional control valve, rebuilding the rear master cylinder and all break calipers, following the right procedures while bleeding, checking all parts for mechanical wear, you name it... ...I had no other option. I am not by any means suggesting to anybody to do this!!! It just seems that for me it was the only option.
Yes, I would still rather fix the problem but after spending so much money with no result and with the riding season at full swing I had no other option. I want to ride "drag free"
And finally after "20K+ dragging" kilometres I had a pleasant ride to work today.
So what did I do?
Drain the SMC/rear break circuit as per the manual. There are two hoses running from the rear caliper (middle piston and the outer two pistons) to the rear master cylinder (MC). They are attached on top of each other on the MC by a doublehole bolt (or however it is called).
I used to lower hose (going to the middle piston /rear caliper) and attached only that one to the MC by a singlehole bolt. Done.
So I now have a separate front and rear break on my ST. I would say the stopping power is down by maybe 10% which I am ok with regarding the neverending story with my rear break. The front break stopping power feels the same.
The next thing I am going to do is order two steel braided lines for the rear break so I can run one to the middle piston and the second one to the outer two pistons - this will increase the stopping power. Now with the one piston it is not sufficient.
And I am goign to fill up the Secpndary master cylinder (left front caliper) with break fluid in plug it up so it doesnt move so much when I apply the front break. And actually I can now also get two steel braided lines for the front break and get rid of all the complicated plumbing of the front break.
As I said, it is kinda sad I couldnt solve this and after so long and so much money I am sure it is some stupid little thing not functioning properly. The ST is a great bike and I dont want to give up on it. I may look for a total with a working break system and install the whole thing once I get my hands on it.
rossilvr
So what did I do?
rossilvr
