I lowered my 1300, yesterday, using a Hagon shock built to lower the bike 1". I bought the shock but the work was done by Walt at Advance Cycle in Mt. Clemens, MI. I had already installed a custom seat built by Mad Cow Custom Leather that got me down some, but not enough, so I opted to change the shock. I was just tired of being on tip toe too often, especially in stop-and-go traffic. I have about a 30" inseam. The installation went well but was a little more complicated than the service manual would have you believe. The manual tells you removing two panels will get you to the shock, but we found that the battery had to come out to get clearance and the only access to the nut locking the top bolt came by pulling up the fuel tank. I bought the Hagon shock with a preload adjuster and that replaced the old one with no problem. The bolt pattern on the new adjuster was the same as the bracket already on the bike. You can do the job yourself, but it's definitely a two man job and it took more socket extensions, etc., than I have.
Riding the twenty miles back from Walt's to home and riding this morning gave me no indication that the handling was in any way negatively affected. In fact, the back end was a little stiffer and seemed more positive, not drifting around so much in turns as the old shock. Of course, I'd dialed out most of the pre-load adjustment in the old one to get the bike down and that had softened the ride a little too much. In fact, on the way back yesterday, I ran into a traffic jam because it was late in the day and it was much easier inching the bike along wih my new ability to get my feet down flat.
There has been some negative feeback on the Hagon shock from a couple of years ago based mainly on the experience of 1 person who found some quality problems with the shock on an ST. Hagon might have had some issues with quality in a batch of shocks back then. I figured that any manufacturer can have issues with a product at one time or another and they do honor their warranties.
We will see how it goes after a Summer and Fall of riding.
