Blue One
Vendor
- Joined
- Mar 19, 2008
- Messages
- 1,080
- Age
- 69
- Location
- Canada (Edmonton Alberta) - Texas
- Bike
- 04 ABS ST1300
Solving any heat issue is really simple. Follow the steps below and no problem at all.
1) Install Staintune exhaust. They run much cooler and help get rid of heat that builds in the stock exhaust. Added benefits, they weigh at least 13 lbs less and sound nice. A small bit of midrange power gain I think as well.
2) Ceramic coat the rest of the exhaust. Looks good and makes a huge difference in operating temperature. With the Staintunes and coated exhaust you no longer cook your lower legs or feet.
3) Drill out the inner cowls to resemble swiss cheese. The added airflow helps remove heat.
4) Install a TT thermostat and make sure the cooling system is operating at it's peak, no leaks or low coolant levels.
All of these things combined, drastically lowered the heat I feel when riding my 04 ABS ST.
The difference was pretty dramatic, making the bike a pleasure to ride, even in July in Texas.
Larry
Larry
