I am getting ready to pull my rear wheel and lube the splines on the def. I have not heard good things about Honda's M77 Moly Paste. Is there an alternative available and if so, what is the name and part number of it... Recommendations.
The current replacement M77 is fine. It is recommended by honda. If you cannot find the M60 then go with M77.I am getting ready to pull my rear wheel and lube the splines on the def. I have not heard good things about Honda's M77 Moly Paste. Is there an alternative available and if so, what is the name and part number of it... Recommendations.
Here is a link to a discussion of this topic (what Moly Paste to use) that contains a lot of opinions and alternatives, you will probably find sufficient information there:
Grease the driveshaft splines?
But... if you are still not sure after reading that post, here's a link to a 17 page long discussion about what Moly Paste to use. By the time you finish reading that thread, either your motorcycle will be obsolete or your driver's licence will have expired:
M77 Replaces Moly 60- Apparently So
Michael
Maybe you haven't been paying attention, but the consensus on this board is that the M77 is not suitable, regardless of what Honda says.The current replacement M77 is fine. It is recommended by honda. If you cannot find the M60 then go with M77.
That is soooo wrong!Shawn K said:If he blazes through that and still has some gumption, he can always do a search for tire and oil opinions.
I will have to respectfully disagree with this commentThe current replacement M77 is fine. It is recommended by honda. If you cannot find the M60 then go with M77.
