Odie1
Hello everyone, back again with questions...
I have read and re-read, then read again many articles on timing belt replacements, and decided it was time. 89K and change on my '96. Everything I have read has been extremely helpful, as always, but I am to a point where I have a couple of questions that I can't seem to find addressed. Maybe I should just know better!
First, I have everything removed down to and including the belt cover, but now need to remove the left hand cam shaft pully cover. What is the best method for holding the engine/cam shaft while removing the bolt? Currently, it just starts to spin the engine. when I try and loosen it. Spark plugs have not yet been removed. I have several ideas, but figured since I am not in a hurry to get done, and before I learned how NOT to do it the "hard way", I'd ask the experts.
Second, I am still fuzzy on the workings of the tensioner itself. I know the spring needs to be removed...or at least unhooked, but how about the bolt in the pulley? Is it only the spring that constantly pulls the pulley tight, or does the spring tension it just so you can tighten the bolt? Would someone cover the process of "de-install/reinstall" on the tensioner for me? Would be appreciated.
I have seen when replacing the belt to start at the crank and work counter clock-wise, and John O's tip about counting belt teeth between marks on the cam pulleys BEFORE removing the existing belt, then matching the new one, but any other tips would be welcomed. And, unless it tensioner pulley bearing is really bad - gritty so to speak - I am not sure how you would determine if it is shot, or to leave well enough alone.
Thanks in advance,
Oh FYI - the (25 year) old belt looks perfect, but on most every thread I see here, they all do!
Odie1
Thanks in advance,
Odie1
