My Elcheapo Wheel Balancer
NSB Florida
2018 GL1800 DCT Tour
Had new tires ordered and needed a balancer. I had the steel, scored used starter bearings at a friends auto electric shop. Took the seals out so they would turn freely. Cleaned the grease out and used light oil. Scored four 10mm bolts, washers and nuts from friend. Notice scratched line across same distance on both to line up even on jack stand. Total cost $0. Use axle to support wheels on bearings. Works great and stores it tool box. Yea I'm cheap.
Kingman, Arizona
2000 ST1100 ABS TCS
004
That's a slick solution for a simple problem, prolly at least as precise as the $$ type.
I don't even bother with the bearings, tho. Just stick a smooth rod thru the axle hole and balance the wheel on the jack stands. Need to "wiggle" the rod to get the wheel moving but it's good enuff.
Heard a good quote the other day that applies,
"If perfect is what ya need, then perfect is good enough; if good enough is what ya need, then good enough is perfect."
acedantinne
Easton,Pa.
04-st1300, 15-1200RT
#7224
Nice, real nice. Simple. Thanks. I take it you use your axles? If not what?
Thanks BoB
Duh reread sorry need that 2nd cup of jo!
Papa
R.I.P. - 2020/02/10
Missouri
Blue Breeze
6388
I'm just curious as to why you scored the bearings and the bolts.
Skunkape
NSB Florida
The bearings were used, therefore valueless. Given to me by the shop. I have done them favors too. The bolts from another friend. We also help each other out. Nothing was "procured" so to speak. :)
Yuma AZ.
st1300
4420
Would you go with obtained?
I think Papa was thinking you "scored" the bearings & bolts, as in scratched a line into them?
I could be wrong tho, it happens quite often...:D
Papa
R.I.P. - 2020/02/10
Missouri
Blue Breeze
6388
Well, I understand now, when I hear of a bearing being scored, I do think of scratched/damaged. I understand now that you mean scored like in scoring a bag, a date, or maybe even a bolt, but I'd rather score with a date.:D
Bigmak96
R.I.P. - 2021/08/07
Rural Mn
04 GL1800 Past tense
7910
That's close George but what I said, if you were quoting me was, "if it's got to be perfect than perfect is good enough, it only has to be good enough than good enough is perfect".:)
Back to the balance deal, I just slid my Axel through the bearings and put it on jack stands. Do you need the other bearings?
Massachusetts
St1300
Balancing the tire using the wheel bearings is pretty tough because those bearings are grease filled and have significant drag. Using the external lightly oiled bearings gives you almost friction free rotation. All you have to do is nudge the tire and it will turn to the heavy spot. Much more sensitive.
Costa Mesa, California
ST1300A
8407
I made my set of wheel balancing tools after buying a very bad quality harbor freight balancer. Their wheel balancer has very bad quality bearings and had a bent bar. It was useless...
I used aluminum 1/4 inch thick plate. It was easy to drill. I used ABEC-7 BEARINGS. I bought a set of 8. They were speed bearings so they have very minimal friction. I did a wood stand very quickly and it does the job fine. I will post the pictures here soon..
