Louie Louie
I live in the hot desert and my batteries don't last long. Is there a specific battery out there for the ST13 that is a bit more tolerable of hot temps. Feedback and advice welcomed!
Louis
Louis
Louie, have you tried the Shorai yet?
I have one that I was using for my commuter bike. Never had an issue...yet. (It was in my '05, then put it in the '04, but my 04 ST1300 is in disarray waiting for me to get it back together, along with a few new parts) So the battery has been sitting (just ordered a charger for it), but it still has juice (tested this weekend).
The one for the ST1300 is:
shorai LFX18ABS12
You can find them online, of pick them up at Chaparral in San Bernardino.
Louis
Thanks, Ive read about that!You shouldn't have this problem but if it gets real cold you have to give the battery a few seconds to warm up just turn the key on and wait a bit before cranking. But in your climate I doubt you will have to worry about that.
I ordered the Shorai 18. Its Kinda pricey but ok. Looks like a great product.
Thanks
If your referring to the Ballistics battery, it's because it's discharge rate when "off" is so small that it's not needed. I haven't heard nor read anything that precludes using a battery tender if you want.Why do some recommend that no tender be used with this Lithium battery. Will it damage it if I use a battery tender?
Cheap battery tenders you can use it with if you like. But higher end - "smarter" chargers have a de-sulfation mode they will kick into that pulses and jumps up the voltage. The increased voltage can kill the LiFe cells.Why do some recommend that no tender be used with this Lithium battery. Will it damage it if I use a battery tender?
Stock st1300 drain is 2.5ma bike off the battery itself doesn't discharge much just sitting so it's not really required.Why do some recommend that no tender be used with this Lithium battery. Will it damage it if I use a battery tender?
Louie, right after I recommended the Shorai for you, I went and bought a Shorai charger. Again, pricey, but I figured since my '04 is down right now and hasn't been started in over two months and I'm not sure when I'll have it running again, I decided I needed the charger for it..
http://shoraipower.com/chargers-c43
