ak85lp
(Paul)
I posted on this forum the other day about a Yuasa battery that was 9 years old. Turns out that is not it so far. I put it in today and same thing. If anyone can suggest what to try next I would be grateful. I'm at work now stewing about it so here's the symptoms and troubleshooting I have done.
Bike (2001 ST1100) has been on about 2 short trips and never gave me one bit of problem. The other night I came home, shut it off and next day nothing.
-when I turn the key I hear a faint noise (not like a click but rather a dull thud) right up by the windhshield? I know it sounds weird but that's where it seems to come from.
-so after getting new battery, adding acid, letting sit and slow charge (as per manufacturer) the charger says 100%
-same noise up front
-checked main fusible link just in front of battery..no breaks
-pulled fuse out from under starter relay..ok and swapped with spare
-replace 10 A fuse in main panel behind battery labelled ignition start
-cleaned all battery contacts and made sure they were tight
-have tried in neutral, side stand up. clutch in all the same
-could not get green connector apart for side stand switch to test
And yes I have toggled the kill switch back and forth several times.
I don't have a volt meter but I guess that is my next purchase. I have a Haynes manual that's pretty good but would like to get some ideas from the experts here.
Frustrated in Canada
