Purchased a 93 ST1100 last month so my old GL500 can have a stablemate. I have been pouring over many posts about the various electrical and mechanical issues that may arise as these great bikes age. My ST still has the original 28A alternator and understand it will most likely be a matter of time until I will need the 40A upgrade. Until then, I have been checking the weak points in the wiring and conducting various PM procedures. I removed the red 3P connector and hardwired the three yellow wires (some deformation of the plastic connector observed). Also noted heat discoloration on the the red wire insulation in the 4P connector that plugs into the starter switch, so I cleaned all the terminals, stripped the red wire to clean copper and installed a new female crimp solder connector.
No damage noted on the VR modular plug, but did clean the terminals and applied dielectric grease to this and other connections. Plan to install a voltage meter as well. While being around cars most of my life (old drag racer) I never really noticed how hot some of the wires and connectors normally operate. Has anyone taken temp readings of these weak connector points on the ST1100? I assume most of the wiring insulation on this bike is rated as 105C (just a guess as it appears to be similar to AWM electrical wiring), so to char or melt various insulation materials, poor/resistive connections must push the temp pretty high.
I am getting 14.6V at the battery at high idle with high beams, so this seems in line with what I read as in the normal range, but curious if anyone would know what temp ranges would be considered above "normal" at these weak wiring connection points.
