JPKalishek
Armadillo Kicker
Yes, but it shows weight moving.Race cars are usually jacking cross weight. Different animal.
It moves while sitting still as well ... added preload especially with a ride height change "moves the weight around" you can watch the pounds move from scale to scale when using the adjustments on a car. racers use it to tune the bike but in a bike. it moves differently than a car. Adding preload on a wheel in a car adds weight to that wheel, then starts loading the wheel across from it (as an example I have moved 5% of a cars weight off of one wheel while sitting on a set of four scales ... btw, a car with 35% on the left rear really 'pushes'), adding it to a bike moves the weight to the other wheel and as there are (normally) only two, the weight can only move from on to the other as the center moves. How much? I would have to try it to see.This is a dynamic weight shift and is only effective while the G-forces are acting on the car... just like the preload on your rear shock, no weight change, just the way it is managed.
Again, if the suspension is topped out as this is done, nothing will change.
