Hi all,
A friendly hello to everyone!
First post so hopefully not doing anything wrong,
Had the ST1300 (2015 ABS model) since the end of last year and clocked up a good number of miles, Absolutely love it
While at a friends unfortunately there was an attempted robbery on the bike, fortunately was using a disc lock and a chain around the back wheel.
As much as I am happy that the hoodlum got away empty handed (can't express enough how much I despise bike thieves ) they have had a good go at the disc lock and i think in the process have damaged the disc and wheel sensor bracket on the caliper.
I had a quick look after the event and gave it a slow ride around the block to home, after feeling ok when moving it about by hand and thought that I may have got lucky despite a couple of tool marks.
Now the first issue that I became aware of was the ABS light staying on, had a look at the front wheel sensor and it looked as if it was off the disc more than it should be and slightly at an angle,
After putting it on stand and using a bottle jack. The wheel feels tight to move, after taking the caliper off on that side it started to move freely again.
To make matters worse i tried to bend the bracket with the sensor on with the palm of my hand and that part of the bracket snapped off . Super annoying but feel like a weld or a cold weld could realign the bracket as I can't forsee any further damage to the caliper, as would preferably like to avoid changing the entire unit.
However onto the subject of the discs, i'm in a real pinch to get the bike turned around again as its my only mode of transport. I would love to replace everything with OEM however the lead times (at least for me seem to be significant), has anyone had any success with the EBC discs and pads? I will give an example of what i'm looking at:
EBC XC- Series Front Disc - MD1154XC - planning to replace both front discs with this type.
EBC Double H Brake Pads - FA388HH Replacing all front pads with these
Any thoughts or words of wisdom? feeling a bit miffed with the whole ordeal!
Thanks in advance
Thanks in advance
