PR3 issue
drrod
Calgary, Alberta
'04 ST1300
8313
I was wondering if anyone can shed any light or have had similar experience with a PR3.
I am currently in Phoenix, having ridden down from Calgary last week. I am riding with a friend who has a 1200RT. After we got here, the next morning his rear tire was down 10 lbs. No sign of a hole. We pumped it up and rode a bit and it stayed up. After sitting overnight again, it was down 8 lbs. Pumped up and this time we took soapy water and went looking for the problem. We found a very tiny pin hole in center of the tread in one of the grooves. The tire has about 60% of the tread left. This is the second time this has happened to him. The last time, we found 4 or 5 very tiny holes. The tire would lose air when the bike was standing but not while it was in motion. When he change the previous tire out, they could not see anything on the inside of the tire to indicate a problem.
Is it possible for air to literally ooze out of the carcass and when it gets hot, expansion will seal it off? Sounds unlikely, but with no evidence of a puncture, we are stumped. Don't really want to make the hole big enough to put a plug in. May try some RideOn (anyone know where we can get some in the Phoenix area?).
Anyway, I was just wondering if anyone had any thoughts on this or had experienced anything like it.
Thanks
Rod
LetErBuck
Brian Oehlert
New Hampton, Iowa
2007 ST1300A
I have a set of PR3's with almost 10,000 trouble free miles.
I love these tires ! I am going to try to get another couple 2 to 3 thousand miles before changing them out for ANOTHER set of PR3's.
drrod
drrod
Calgary, Alberta
'04 ST1300
8313
I too run PR3's and rode the identical roads with my friend and have no issue. We did ride about 25 miles of gravel/dirt so it is possible that a very small, sharp rock penetrated the tire just enough to cause the problem but there is no sign of damage to the rubber around the hole. My tire is down to the cords (time to call Tim) so it should have been more prone to a puncture. The curious thing is that this is the second PR3, on his bike this year, that has done this.
Rod
drrod
drrod
Calgary, Alberta
'04 ST1300
8313
Bit of an update. We put some Ride On in it and it appears to have plugged the leak. The bike is going to be stored for a couple of months now so it will be interesting to see how/if the Ride On holds up.
Rod
VFR
"Uncle Larry"
Idaho for good, no mo Cal
The finding and diagnosis don't sound like a match to me.
That is kind of what I was thinking. How does a dirty rim equate to a pinhole in the center of the tread???? I've done my share of tires but I'm certainly not a certified tire guy. How about a little enlightenment here???
Cincinnati, OH
7482
Rod
I'd definitely store it on the center stand so that it won't tip on its' own if the tire goes flat...
drrod
drrod
Calgary, Alberta
'04 ST1300
8313
It is on the center stand with the "hole" at the bottom so any Ride On that migrates down will sit on top of the hole.
Rod
The Dan
The Dude Abides
Vendor
Watertown SD
2009 ST1300 ABS
7982
Tim may of had a relapse moment...LOL...Were just glad he can still sell tires..
