i fitted new front pads for the first time today after looking at instructions from the haynes manual it was pretty straight forward,then i came to fitting the rear pads thats when the problem started,
in the manual it says to remove the pad pin which i did, then it says push calliper against disc (i coudn't understand how you can do that without first removing the calliper bolts but i tried anyway) so the pistons get pushed right in,i tried that but it woudn't budge.
i removed the pads , so i thought just get a long bit of wood and force the pistons back but when i did that instead of pushing the pistons back the whole calliper moved towards me leaving it hard against the disc i've tried pushing it back but it won't move.
i didn't want to use to much force in case i ended up breaking something.any suggestions would be great thanks
