I'm really warming up to the idea of building a one wheel trailer for my ST1300. I've scoured the internet looking at everyone's designs, everything from Uni-go, Bobbit and Eaglemate to all the work of art homemades around. I really like the idea of using a golf club hard travel case (http://www.securegolftravel.com/skb-ata-staff-golf-travel-case) for the storage. I can get the center of gravity real low and can stuff the heavier items closer to the back wheel. As well, I can make the case so it can come off for going into the hotels, etc... That also leaves me a platform to mount other cases if I need. (Kind of like George's)
Ok, long story but now into my questions:
Do you notice a difference in pulling a shorter trailer (Unigo) as opposed to a longer one like 6' or better?
Is suspension really required? Understandably, suspension will save wear and tear on the whole system.
I like the idea of the universal joint for coupling. Do you notice much rotational play in the joint and does it effect the stability of the trailer?
I also like the idea of the mounting plate Uni-go uses. When mating the two halves (trailer to bike) and installing the pin, how much play is forgivable in the two?
I know getting the center of gravity as low as possible will help stability and wind problems. With trailers with the wheel under the storage, does stability become a greater problem?
