Hey all;
This being my first post it may as well be here in the brakes section.
I had read so many posts here about this topic with lots of great direction that certainly saved me plenty of headache.
My bike is a 2003 w/o ABS so thank heaven for that. I have owned it for a few years and the brakes seemed to work well until this spring.
I took my wheels off to get new tires put on and was able to reassemble successfully with some effort.
I rode it for a few weeks and then noticed more (there always was a little) brake scraping when pushing it around in the garage.
Took it out for a 5 km ride with light even braking front and back. The rear disc was too hot to touch and the front ones were not near as bad.
After my research here on the forum I called my dealer to order re-build kits for the SMC & RMC.
These kits were back-ordered for over 2 months. That is an eternity for any motorcycle rider in Canada and especially in Saskatchewan.
The complete units were available much quicker and at quite a bit more cost.
However, to quote JFHeath, "ST parts will not be available forever" so I decided to just spend the money and order a new SMC & RMC.
It looks like there is a part number change up on the SMC anyway and mine is probably original to 2003 so not a waste of money in my mind.
In the mean time I checked over the rest of the calipers and cleaned all the piston (w/o removal) and got it ready to put in the new parts.
The new parts arrived and I installed them. I did have to bleed the system twice to get a good firm handle & pedal but it seemed to go pretty well.
I then tested out the brakes before putting everything back together and the rear brakes still dragged when using the pedal. I came back the next day and bled
the system again and found a few small bubbles but I'm not sure how much small amounts of air in the system would keep the pistons from sucking back.
Still the same result.
Time to call in the pros. I went and spoke to my local dealer about the problem and the service writer even knew about the complicated bleeding procedure.
So I booked it in and brought it down. I have known this shop for many years and trust them with any of my equipment.
I just spoke to them and they had rebuilt the rear caliper with new seals, bled the system and took it for a test ride.
Still dragging slightly. The technician started working with the rear brake bracket and stopper bolt and found an alignment problem.
He said when he takes out the stopper bolt the brakes come into alignment better and stop dragging.
They tried a different stopper bolt (off a similar bike) and it didn't seem to help.
The brake bracket is also on back-order until end of July to mid-August so no way to try that easily.
Here is my question - Could it be the bracket and/or stopper bolt or just the mounting pins? What else could be the cause?
These bikes are not common here in Canada like they are in Europe.
My wife and I will be in the UK in July so I am tempted to order parts at a London Honda dealer and pick them up when I am there and bring them home.
Thank you so much for all those that took the time to post about this and help others.
