No worries. You are right that I should have started a new thread rather than piggy back another.I see you list a 13 as your bike. Excuse the question but this is an 11 you're working on, which year? ABS? I'm guessing an ABS1 bike. I looked up a ABS1 bike. It matches your posted fiche. It also shows spacers in both side forks. Sorry. I did not realize that. With you posting in another thread I looked up at the OP's bike and seen it was ABS2. Never thought the OP and you asking the question was a different person. Not trying to be mean but this is why we start new threads. It helps us help you. If I had seen yours was a ABS1 I could have told you right off that it should have a spacer in each side. No worries tho. I think we are closer to an answer.
I don't have the time right now, but will see if I can find the spring length tomorrow. Unless someone else gets the Honda book out before me. I am curious how you have the stock length spring but no spacer?! Odd.
1993 ABS1 front forks.
I have a 94 ABS/TCS and a 2010 non-ABS (to help muddy the water ). The 94 N. A. fiche shows a spacer but does not list a part number. The list completely skips it.
I have stock springs as they measure roughly 18 5/8in or 474mm.
I pulled this over from the other thread to consolidate.
I did some searching on the Honda England parts fiche comparing the Police version forks to the N. America civilian model. The police variant was offered in England in 1993 (RH Fork Assembly P/N 51400MY3781) and 1995 (RH Fork Assembly P/N 51401MY3781). The 1994 N.A. civilian ST1100 ABS/TCS uses the RH Fork Assembly P/N 51400MY3781. The parts fiche do not show a spring collar for the RH fork.
The N.A. fiche calls out 3 spring joint plates used while the England fiche calls out only 2 used.
I'm not sure why the P/N is different from 93 to 95 as both fiche look the same.
